TwinTurbo.NET: Nissan 300ZX forum - Na Fuel Controller on a TT ECU, will cause a Lurch
Subject Na Fuel Controller on a TT ECU, will cause a Lurch
Posted by Cjw3 on August 14, 2013 at 6:44 PM
  This message has been viewed 291 times.
In Reply To hmm.. posted by inf on August 14, 2013 at 11:45 AM
Message The TT ECU ( Hardware ) will be selecting a 3 Step Fuel pump Speed.. the NA Hardware can only do a 2 Speed.. the TT ECU Hardware will shift off the NA Fuel Controller when the TT Hardware wants step 2. fuel pump Controller shift off, fuel pressure will drop and the car will stumble, then the TT Hardware will shift to Step 3, and the NA Fuel Controller will shift back on.
You dropped in a NA ECU to test.. was the Injector size programmed properly into the NA ECU prom?.. if not then you did a mixture change as well..
